cosa clutch plates how long in oil
soulboy
i no realy should be 24 hrs or so but what is the earlyist i can get away with ..also my newfren springs a quit a bit longer than the ones i took out what will this do cheers ;)
ducksta
if you get your hands dirty by rubbing the oil in a few hours should be ok longer springs usualy mean more tension
roadrunnerian
you might find the clutch biting piont changes mine did when i put in some pinasco springs
soulboy
cheers fellas
    Users browsing this forum: Google [Bot] and 13 guests
