speedo magnet
Gunny
I've got a Kosvo digital speedo fitted into my RD everything was working fine but ive lost the magnet off the front wheel so no speed reading , everything else working..
Are these chipped magnets or can i replace with any sort of magnet same size ?
any magnet should do it
Gunny
cheers mate
bizzly
Gunny wrote:I've got a Kosvo digital speedo fitted into my RD everything was working fine but ive lost the magnet off the front wheel so no speed reading , everything else working..
Glue it on as well :D
Bizzly, are you using the sensor with a SIP speedo? If so, did you use the SIP instructions or is more info needed as it refers to anther sheet? A mate seems to be struggling with his :-?
Many thanks
bizzly
soulsurfer wrote:Bizzly, are you using the sensor with a SIP speedo? If so, did you use the SIP instructions or is more info needed as it refers to anther sheet? A mate seems to be struggling with his :-?
Many thanks
No mate, sorry..I'm using a koso speedo
Is anybody using the magnet / sensor with a standard type disk hub?
If so, how have you mounted the sensor?
    Users browsing this forum: No registered users and 66 guests
