Dzuss Nuts for rear runners
Bilko
Main scooter: LI150
I'm finally putting some time aside to get work on my LI done. I'm looking at getting some Dzuss fasteners for the rear runners of my LI. Does anyone know if these would be the right size?
Dzuss Nuts
Bilko's Oily Blog
Thinking of doing the same, as I understand you need to add the total thickness of panel you are trying to secure (footboard +rubber washer)+ 7mm for the fastener and then buy the closest length of fastener, either rounding up or down.
Why are you looking at the rivet on type receptacle? won't the push on type work? Pro bolt have a massive selection http://www.pro-bolt.com/ but costly (look quality though) may give you a better idea of what your looking for in the way of a fastener then look for best price, be aware the rolled type are allegedly rubbish, stick to the machined type they have a much more definite 'lock' on them,probably the best way to tell the difference is price, visit a few web sites and you'll see what i mean.
Good luck
Rich
TED CRUD
javascript:;
Smash Ya Pastie
Washington Posse s.c
TED CRUD
http://www.ebay.co.uk/itm/140958000779? ... 1497.l2649
you can put them on top or underneath ,i was going to use them with skateboard tape on top instead of runners and or the the bridge mounting kit
Smash Ya Pastie
TED CRUD wrote:javascript:;
C#
Bilko
Main scooter: LI150
In my haste I wasn't looking at the fixings properly.
Thanks lads.
Bilko's Oily Blog
    Users browsing this forum: Amazon [Bot] and 9 guests
