series 2 panel help
weedodger
Main scooter: Indian gp casa 185 and 200
my series 2 has a replacement/home made panel holding mechanism, it doesnt work too good, the side panel handle slips about half inch down, im scared it comes past the bend, and the panel comes off!
Can you buy a replacement, or could i cut into the stainless bit, so the locking piece falls into place, stopping it sliding down and past the corner?
Hope this makes sense
what i mean is should i cut/grind a few mm off the bottom of the straight edge, so the panel bit secures in the "step"
goonerman
Main scooter: Series 1 Framebreather
You can buy a replacement part, but it is a weld-in piece that is welded to the rear of the frame. I have one in the garage, if you're interested pm me
Not Quite Right
ssteam177
Main scooter: vba malossi 221, api series2
Some people do that modification to make it easier to change the rear tire
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
weedodger
Wonder if a split pin through a drilled hole would be a better option to stop movement of panel handle?
Supereibar
I have the welded one held with screws. Works fine.
    Users browsing this forum: Semrush [Bot] and 8 guests
