BGM Stator/Flywheel Poll
What Flywheel combination with BGM Stator
BGM + Indian Sil Flywheel
12
48%
BGM + AFR Light Flywheel
5
20%
BGM + AF Ducati Flywheel
5
20%
BGM + Other Please specify
3
12%
Total votes: 25
RinB
Please Vote on your combination of BGM Stator & Flywheel that seem to work
Also please post any mods you have had to do to get it working
Thanks
Smiffy
Dimitrios_231
BGM 120W stator with GP Elemec flywheel,no problems at fitting but can't get the timing less than 22.Apart from that, it works fine.
BGM 120W with new AF lightened,doesn't work :( .
I'm waiting to try the MB lightened (2Kg),this week.
RinB
Dimitrios_231 wrote:BGM 120W stator with GP Elemec flywheel,no problems at fitting but can't get the timing less than 22.Apart from that, it works fine.
Good feedback m8
Im sure the MB one will work
I've just fitted this combo, no fitting issues but not tested it yet as other things, not allied to ignition, still need doing before it's a runner.
Dimitrios_231
Couldn't get a steady tickover.
Couldn't keep the revs.
A strange sound was coming from the maghouse.
I was told that the new ones in combination with the GP mec crank that I have,didn't need any mods.Not in my case.
al-super3
I am running bgm 120 with standard sil flywheel.
I swoped from a sil stator that was in there for 6 years with no problems in serch of more power (electric) but is no better
When is some one going to do a 120 wat regulator to match
Timing wise no problems
Cheers Al
Scream at me until my ears bleed
teamsequipe
BGM 120 using a standard Ducati Italian Electronic flywheel, no issues.
Ihateyoubutler
Bgm 120 with a jb lightened sil flywheel (plastic fan).Timed up no problem at 19 degrees.Seems to be enought stator adjustment left to fit augusto when a I've few more miles on the engine.
Jonny G
noob
Af Lightened Flywheel, BGM 120W Stator and an MEC Crank. 1mm machined from the mag housing face. 300 miles with no probs whatsoever !!
RinB
Any more voters
Another question are the AFR light flywheels old or new type ie new have a packer in between
boss & flywheel.
Also 120w BGM old or new ie new ie pickup is no located futher in Ie laminates taken off
from manufacture.
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 3 guests
