PX disc speedo cable
boonyed
All
I am rebuilding a set of PX disc forks and am going to replace the speedo cable, inner and outer - the type with the plastic clip connector to the speedo. Can anyone tell me whether or not there is supposed to be a plastic gromet on the bottom fork end under the black rubber and bolted plate? I wasn't really paying attention when I stripped it!
Cheers
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Do you mean the support block that sits flush in the hub ?
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
boonyed
When I took the small oval plate off the bottom end and pulled the cable out of the hole, I thought I saw a nylon gromet around the bottom of the outer cable (where the rubber goes around the outer cable and sits in the recess under the late). It could have been part of the plastic cover on the outer that had 'rucked' up, but I wanted to check before rebuilding it.
The new cable didn't have a gromet with it when it came.
Shaunbond
Order is worm, worm retainer, rubber grommit then oval keep plate. :D
Serial scooter rider...
VMSC Committed to Scootering for 25 years
Shaunbond
:D like I said! :D
Boothy_the_makem
Sorry mate i meant to post this last night
http://www.rondaleyscooters.co.uk/speed ... i1198.html
Sh1tty android phone crashed yet again and nipped out to scooter club and forgot me phone. Glad yer sorted anyway ;)
Bofs
Watch out though, the PX Disc set-up, top pic, (and Grimeca disc) uses a shorter top hat than the old PX drum brake. Make sure you get the right kit.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
boonyed
Superb, cheers
