Piston bottoming out
Magalluf
Hi all
I have a Mugello 186 which I have fitted with a Mecure 60mm crank. I had to dremel the case a bit to get it to turn smoothly as it was touching slightly. Now I have mounted the piston I see it is touching slightly at BDC is it just a case of shortening the piston a bit or is it more serious.
cheers
Steve
camel
so you have increased the stroke of the crank from 58mm to 60mm....ie an extra 2mm......so half the difference which is 1mm.....that is the size of the packing plate you now need for under the barell...in theory.
cezeta
you will need to take a bit off the piston, next time use a 60mm crank with a 110 rod
Magalluf
Hopefully after shortening the piston skirt there wont be a next time. It´s easier and safer with a 58mm
cheers
Steve
Minority
Main scooter: Li230 S3
camel wrote:so you have increased the stroke of the crank from 58mm to 60mm....ie an extra 2mm......so half the difference which is 1mm.....that is the size of the packing plate you now need for under the barell...in theory.
That would fix a potential problem with the piston rising above the cylinder at TDC, but would do nothing to stop it hitting the casing at BDC ;) .
Knowledge
Good point Minority.
If you cut the skirt, you will alter the inlet timing (Mugello has piston controlled inlet timing, I think....). This might be to your advantage, but too much inlet timing compromises bottom end performance (though top end can be FUN).
Martin
Minority
But I guess the 1mm packing plate would raise the inlet port which may compensate for trimming the piston in terms of inlet timing.
camel
quite right
i stand corrected :oops:
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
