gear oil
soosh
It's a try it and see scenario then.Buy the stuff from a respected knowledgeable scooter dealer if unsure.
GP Kevo
Do not use "limited slip" gear oil as this refers to a limited slip car differential. Do not use "hypoid" gear oil as this is is for ring and pinion rear axles on cars. I only use / have used: Rock ST-90, BelRay Gear Saver for wet clutch 80 wt., and Maxima MTL-E 85 wt. (my favourite but can't find it around here) and Runge 90 wt. from Germany.
hydra
Ah yes!!!, at last GP Kevo an appreciation of Maxima's MTL 85, far superior to ST90, and I sell both. Far more protection for your Gearbox and engine bottom end.
