fist full splutter
bazza3004
scoot runs fine up to say half throttle but when I give it a fist full it hits a point in the revs were it starts to splutter and wont clear if I hold it open. I upped the main to a 128 which improved it but its still there,although if I put choke on it takes off like a scalded cat. Does this mean I need to go bigger on the main. Greatful for any pointers.
camel
give a full spec of your engine and carb size matey and youll get plenty of pointers.
mick1
Main scooter: Li Avanti 225
Check my post about "Fast Flow" taps. may be a problem with your tap........like Camel says post your full engine spec' and you'll get more replies
bazza3004
gp 150 WITH GT186 top end , 28mil phbh and a sterling pipe. jets are 264 atomiser 128 main and the other jet i no is the one that screws in next to the atomiser (pilot jet)? this one is a 50. it also has elec ignition (indian i think).
the fact that it runs better at all with the choke on means that its weak over 1/2 throttle ...a bigger main jet may correct this but it could be also that your atomiser/needle combination is weak also ...my advice is to get it on a dyno .
GP240
bazza3004
cheers for the info. rich t did tell me to fit a av266 atomiser and an x13 needle so i will replace these and see how it goes. thanks for the link to carb set ups to.
    Users browsing this forum: Semrush [Bot] and 27 guests
