timing question
fairspares
[ With a dial gauge, for ignition timing, there is no need to find true TDC so it's accuracy here is irrelevant.[/quote]
so how do you know were the firing point is if you dont find tdc first? this is a new method to me.
victor
Main scooter: Tv175 but currently a SS210 :)
fairspares wrote:[ With a dial gauge, for ignition timing, there is no need to find true TDC so it's accuracy here is irrelevant.
so how do you know were the firing point is if you dont find tdc first? this is a new method to me.[/quote]
:D
The disc MUST be more accurate due to the play you have around the TDC. Positive stop will give you the EXACT centre i.e. TDC
bazza3004
Thanks for the replies/debate. I don't have a timing disc at the moment so I will have to use a dial.
firekdp
victor wrote:
fairspares wrote:so how do you know were the firing point is if you dont find tdc first? this is a new method to me.
:D
MUST it :?: :?:
The dial gauge is measuring piston travel NOT degrees. As the piston isn't moving during the dwell the gauge can be zeroed anywhere during this period. You'd have to be pretty dumb to try and find exact TDC to zero it when it will read zero wherever it is in this period, wouldn't you? ;) .
So zero the gauge when the piston has reached uppermost travel, turn the flywheel back past the required mm needed and then in the correct direction to it, mark the mag housing adjacent to the arrow.
ONE mark needed, one margin of error, due to parallax etc, not FOUR.
Muppet
firekdp wrote:
:D
MUST it :?: :?:
C’est la vie
Yanker
Pepot wrote:this disc its easier.I also use it to find the TDC by the positive stop method described in the stiky's book.
A few seemed to have missed or misinterpreted this part of the post?: I think "Pepot" is saying 'find TDC by positive stop, align the disc and mark-off ignition point.' I like the positive stop method for TDC determination (due to the 'dwel' factor), and like his disc as it will be more accurate than one bolted to the end of the crank. But each to their own.
Pepot
Main scooter: servetta LI150 serieIII GT186
Well,at least for me it's a relyable sistem.The image of the timming disc I posted has a very poor resolution.I have a better one in PDF,but don´t know how to post it here.
victor
I'd love the pdf version can you mail it to me? I'll pm you my address.
Pepot
It´ll be a pleasure!
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
