Piston to bore clearance
soosh
By the sound of that "slap" sound.
Similar to the sound I had on a fresh rebore I had a few years ago. I had 3 thou clearance...each f@@king side of the piston!
TS1-200
Adam_Winstone wrote:This thread was never about what clearance you would start with on a rebore, rather, it was about how big is too big on a used bore.
TS1-200, how are you getting on?
Adam
Put it all back together Adam, runs fine, little bit noisy at low tick over speed, but runs fine. Will look to doing a proper rebuild next winter.
Keep on keepin on
TS1-200
Double post
Keep on keepin on
Adam_Winstone
Adam
Cool :)
hatch
Main scooter: Li 150 Special
soosh wrote:
hatch wrote:Af Rayspeed Mahle pistons are the best ive found / always use now, standard type and there beefed up to stop cracking on the skirts , with 200 careful miles running in on flat roads you can do these at 2-2.5 thou , with fully syn at 2% , never had any problems
Ditto. Some people laugh when you tell them that but i was told they are the best "standard type" on the market by the guy who did mine.Cheap as well,cant see why you would spend more unless you had something very revvy or had massive exhaust port.
Yes there great , best you can buy and why people use more than 2% in standard bikes ill never know
Grumpy225
soosh wrote:By the sound of that "slap" sound.
Out of currisioty, how are you measuring your piston to bore clearence?
hatch
bristolmod wrote:ditto- always used Mahle and worked down from 3 1/2 thou to 2 1/2 thou clearance now, with no issues whatsoever. Mix at 3% semi. Loads of short, reasonably hard cycles on rebores and well run in by 300 miles.
Hello Chris , on the mahle piston they can stand the tighter clearance so you dont get slap , 4 thou on these pistons there clapped out , try going a bit tighter 2/2.5 thou
craig
Muppet
mahle borgo hepolite same same
C’est la vie
soosh
This was done years ago by Malc Anderson at MSC,he just had some feelers down each side of the piston to show that what a perfect job the other company did.He wasnt being exact,just showing it was shite and needed doing again and they did it while i waited and was perfect.Obviously if being exact,i would use some verniers.
Adam_Winstone
^... not like your next ride was going to be a biggie though :shock: (Milan 97)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
