Tickler - Pod woes 07.04.13
BSSO race info, reviews, plus rider and scooter tech info.
Ken Tucky
Tickler,
Re Pod last weekend.
If you're reading this....
Tell the Indians to rest easy in their beds, you're stator is probably OK.
Thanks for loan of stator.
Whereas I now have plenty of crank cheek clearance, they're at least 4mm further apart thann they should be & the bike is lighter now due to the metal that has been ground off the inside of the mag housing and it was 'dead easy' to get it out of the crankcase...
No wonder it wouldn't run eh.
Looks like its another trip to Cranks R Us .....not.
Get some new fuel btw ......
Mr Tucky
Darrell Taylor
Main scooter: LAMBRETTA
is there any results or sprint reports about ,or if not could you provide one
cheers
tarmac tickler
hee hee hee,, taper on mine is shagged as well,, Li flywheel boss may fit on it ,, worn big time boy ,, luckily got a spare crank but got the wrong rod in it and its welded!!! bugger,, its a grind man,,,its a grind
pauls pulled his back out cutting down trees,, p1551ing in a bottle he is,, p1551ing in a bottle
Sonny
These are the NSA results for you
Class 12 - Scooters 13.34 Record Stuart Owen
282 Jamie Newbold Italjet Dragster 186cc 14.14 14.14 84 14.19 86
276 Pete Newbold Italjet 172cc 14.39 15.69 73 14.39 87
285 Darreyl Ward Lambretta 238cc 14.84 14.84 88
277 Richard Baker Lambretta 238cc 14.87 14.89 82 14.87 79
287 Paul Priestley Lambretta 240cc 20.20 20.20 63
Pete
If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man.
Sonny
And The X race results
Superstreet Lambretta over 210cc max Record TBE
1 1652 John Francis Lambretta 240cc 15.74 15.88 85 15.74 86 16.64 80 16.69 65 16.33 86 16.59 80
Street Vespa up to 190cc Record TBE
1727 Martin Murray Vespa 90ss 125cc 15.80 15.80 80 16.04 79 16.24 83
Pro Street Geared Scooters unlimited cc Record TBE
1800 Keith Hudson Lambretta 252cc 14.52 19.07 66 14.79 85 15.21 86 14.76 89 14.52 88 14.70 87
Competition Race Scooters up to 210cc Record TBE
1850 Martin Murray Vespa Special 154cc 14.74 15.84 83 16.50 86 16.23 84 14.74 88 16.48 61
Automatic Top Scooter Record TBE
2765 Joe Elliott PM Tuning Sprinter 11.64 11.90 111 11.72 111 11.81 113 11.64 114
Scooters Class 13.10
1 2609 Adam Chaplin Gilera Runner 183cc 13.67 14.97 66 13.67 91
Ken Tucky
Pete,
NSA results - the 'truth'.....
me - 89 mph with a seize and twisted crank - not bad eh ...for a three gear run/blow up.
Paul Priestley - crank went also.
Darreyl - well you can see what happened above.
Pete Newbold - shagged transmission pulley followed closely by shagged barrel.
Jamie Newbold ......OK!
Good job the weather was OK then.
Mr Tucky
Ken Tucky
Correction - now with eye aids on ....
My speed 82/79mph
Mr Tucky
