bearing race removal tool
satans reject
Main scooter: lambretta gp
Has anyone found a tool for removing the bearing race on your crank? Currently playing around with jubblie-clips, grinders and heat........ There's got to be a better way!
DigDug
I used a Dremel on my last one - quite straightforward following Sticky's instructions.
Did you have to do that?
yes look in stickys book .. the pics alone are better than any discription i could give
ove
Lincs lambrettas do one, its very expensive if you're only going to use it a couple of times. He is only 25 miles from me so i popped in and he removed it free of charge. My crank was f@@ked, so he put collar straight on my new crank and 3k miles later and no problems. Top tool, russ top man but sometimes talks out of his arse!!
    Users browsing this forum: No registered users and 59 guests
