Rear brake cable dilema
bazabod_downunder
Having real probs with the cable clamp that fixes to the pedal, I've tightened the cable in the clamp through the bolt as much as physically possible but keeps it pulling through when the pedals pressed......any ideas?
bizzly
Have you tried putting a washer on the bolt then putting cable through, then another washer before putting the last clamp on ?
bazabod_downunder
bazabod_downunder wrote:Having real probs with the cable clamp that fixes to the pedal, I've tightened the cable in the clamp through the bolt as much as physically possible but keeps it pulling through when the pedals pressed......any ideas?
Looks like I maybe missing the wavy washer
AQs Bizzly said, use some washers, the bolt isn't threaded all the way up and your nut is on=bviously reaching the end of the thread before it clamps tight. The wavy washers are quite thin so you might need something thicker. Do it up tight and it won't 'vibrate' undone without the wavy washer.
bazabod_downunder
coaster wrote:AQs Bizzly said, use some washers, the bolt isn't threaded all the way up and your nut is on=bviously reaching the end of the thread before it clamps tight. The wavy washers are quite thin so you might need something thicker. Do it up tight and it won't 'vibrate' undone without the wavy washer.
The bolt is threaded past the cable hole but can see a washer probably would be needed, I'll give it a go....gotta say it's probably a s**t part & may get another from MB if it doesn't work out....thanks for the advice
Daggs
Personally i'd be surprised if a washer or lack of a washer made the difference.
Are you getting the two clamping plates round the correct way?
Take a look at the picture in the link.
http://www.scooterrestorations.com/lamb ... clamp-set/
Knowledge
Whilst the problem here is related to the fixing at the front of the cable, I supply a link to the instructions for fitting my QA brake cables, as there are useful pointers for fitting the cable to be effective.
http://colchesterdvlc.co.uk/martin/QA_installation.htm
I draw the readers attention to the use of a cable tie in order to take-up the slack on the inner cable, which works well whether you use one of my QA cables, or the traditional set-up.
Martin
Knowledge wrote:I draw the readers attention to the use of a cable tie in order to take-up the slack on the inner cable, which works well whether you use one of my QA cables, or the traditional set-up.
That is a top tip Martin, used it a couple of times now 8-)
ktmh5
Main scooter: GP225 Mugello
Me too, top tip. :D
bazabod_downunder
Daggs wrote:Personally i'd be surprised if a washer or lack of a washer made the difference.
Yes it's round the right way, otherwise it wouldn't fit on the pivot
    Users browsing this forum: No registered users and 20 guests
