PX front hub D washer
brucie
Main scooter: vespa px mk1
Am putting one of these on my mk1 px
http://beedspeed.com/vespa-brake-front- ... r5d0fddgr3
problem is when I put shim washer on, then new disc hub, d washer then circlip I can't even see the groove that the circlip goes onto on front axle.
Have tried it without shim washer but its still to thick.
I can get circlip on to fit by replacing D washer with a thinner normal washer.
Want to know if its important that D washer is there or would a normal round washer be okay to replace it.
ArmandTanzarian
I had similar issues with a ScootRS disc. I had to get the hub machined to make it fit.
