Jockeys Boxenstop Headlight
lammydave
Anyone fitted one of these and able to post a pic?
i'm a bit confused by the fitting ring they supplied.. no instructions!
Looks a nice bit of kit tho....
lammydave
lammydave wrote:Anyone fitted one of these and able to post a pic?
just seen this...
http://scooterotica.org/forum/viewtopic ... s&start=40
a picture is worth a thosand words... 8-)
Stop faffing about man and take some pictures. :D
lammydave
Doom Patrol wrote:Stop faffing about man and take some pictures. :D
it's all reday to fit now, got me wiring all sorted... but no time now till saturday.... will post pix then....
David, is your adapter ring flat and require bending in all sorts of directions before fitting? My SX one was, and I have to say its not the easiest thing to manipulate without making a pigs ear and completely wrecking the ring. I would have thought this would be ready to fit and can see this causing a real problems for a lot of people :roll:
Evesy
Main scooter: Jet 200 with Imola 186
I fitted the one into my jet with no problem
At all. I was very pleased with the fitment and even more pleased with the result
lammydave
soulsurfer wrote:David, is your adapter ring flat and require bending in all sorts of directions before fitting? My SX one was, and I have to say its not the easiest thing to manipulate without making a pigs ear and completely wrecking the ring. I would have thought this would be ready to fit and can see this causing a real problems for a lot of people :roll:
the one i have is for my Jet, and was easy to bend
a friend of mine has one for his sx and said it's a bit flimsy... i'll find out soon as i've ordered one for the pacemaker....
Looking at the pictures online, it does look like the SX type needs more bending and is more flimsy too leading to more difficulty, the Jet and Li look quite easy to do.
lammydave
soulsurfer wrote:Looking at the pictures online, it does look like the SX type needs more bending and is more flimsy too leading to more difficulty, the Jet and Li look quite easy to do.
Any chance of sending me some pix, as mine will be here next week.....
I'm reasonably handy with tools and this did present some problems, you can see the ring distorted, but I managed to fit it in the end and it seems a great idea.
BTW, this is a Winter Model rim, but this is irrelevant really as the difference is minor, apart from the fact it will also fit.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
