Fag 6305.2zr
Magalluf
I´ve started building my engine this weekend and have just noticed that the drive side bearing is a 6305.2ZR is this bearing OK to use or do I need to get another one. Its the one with 2 metal covers so you cant see the bearings.
cheers
Steve
warts
Main scooter: honda
The metal shields are to give greater mechanical protection. There is a "rubber" seal inside. You can prise them out if you only want them on one side.
Can't see any reason to not use them, I fitted them as wheel bearing to mine.
gaz_powell
the shields can be popped out but it should be a c3 rated bearing
