gear box oil
roadrunnerian
Hi Tosh,
you should use sae30 oil fill up to level m8 i always fit just a touch more in might see you on the midweek ride i presume the clutch is ok now i have some in the garage give us a bell if you need it m8
Tosh
hi ian might give u a ring mate,found some sae30 but not enough,also ta donnie for the reply but if we use st90 in the lammy`s
what`s the diff with the vespa clutch that we will as you say f@@k it up..
GLscoot
- Main scooter: Vespa GS150
250/275ml of 30sae. Easiest way to fill your casings with oil is with a syringe. If you have already removed the oil, sometimes it may take a little less, as there will be oil still inside the engine. I use Rock Oil.
roadrunnerian
Hi Tosh glad you are sorted might see you wednesday m8 i use a small oil can to fill my vespa its orange in colour
