Winter Model, Summer Restoration...
you like the chrome look powder coat mate, I ruined mine on the wheels and rims as I used wheel cleaner to get the crud off which made them dull and flat :-(
soullad wrote:As ever, great attention to detail Mike. You've no damper top lugs welded on for your bgm dampers, are you using clamp on brackets instead?
I had the forks coated whilst contemplating whether to use dampers with an anti dive brake, but now I'm using the German CNC damper brackets, you can see the marks where I've put them on and removed them as the coating is a three stage process and quite thick. The brackets are spot on for alignment, although any brackets seem to touch the inside of the mudguard, some spacers should help with this. I'll post some pictures once assembled ;)
Lesson learnt there Andy, warm water only, although brake cleaner doesn't do any harm, but strictly no abrasives ;-)
MADSPEEDRB260 wrote:
soulsurfer wrote:
MADSPEEDRB260 wrote:Ye get some photos up ?
You've seen it ;-)
http://scooterotica.org/forum/viewtopic ... 94#p187994
Yep i know whitch one it is now. When's it going to be finished 8-)
It'd be nice forAugust Bank Holiday, but that might be pushing it...
I got the forks built today, the top damper brackets toe in a bit to help with mudguard clearance, I'm not keen on this so will look at spacing the mudguard out...
gpts1
Love the upper shock mounts did you make them?
soullad
Look like LTH mounts to me
soullad wrote:Look like LTH mounts to me
LTH, Jockeys, Worb5, German made by MMW, as are the brakes I use...
Budenzauber
Is this the 200 mm or 220 mm version?
Budenzauber wrote:Is this the 200 mm or 220 mm version?
This one is the 220mm disc, available from Worb5.
First paint done, HURRAH!...
Whilst I'm quite pleased with the finish, the attention to masking off the chrome powder cost was slack resulting in a dry feel all over and overspray behind the bridge piece and the number plate areas inside the seat arch :-(
Not the end of the world, but does anyone know how to remove this? I tried thinners on a test area and it turned really sticky very quickly...
    Users browsing this forum: Semrush [Bot] and 11 guests
