nk or franspeed race exhaust
roadrunnerian
hi at the moment running a ts1 225 tmx35carb with li 150 box 16x47 sprockets with the franspeed race pipe would i gain anything with fitting a nk pipe thanks ian :D
No, not in my opinion. Having tested the Franspeed on a TS1 back-2-back against many other pipes, I'd say you have got the pick of the bunch for overall performance. The only reason to change would be if you wanted less power and a more sedate ride.....
and a less usable spread of power lol
twenty eight
got almost same set up i would not change the pipe
rbgaz
ive had the nk race,franspeed road, and the franspeed race on my rb230 and imo the best was the nk race
roadrunnerian
thanks for the replies will stick with the franspeed race then
boonyed
I have a similar set up, but with the JL road pipe. I was considering an NK as the stainles JL keeps rattling itself to bits (had to have it welded 3 times now). Its a toss up between a 'normal' steel JL and an NK, but all i have to go on is the scootering write up.
Can anyone shine any light on my dilema?
p.s. sorry to hijack your thread Ian
TS1-200
For my part I run an NK, good power, not expensive, fitted well and after 18 months still intact, bit on the noisy side though.
Keep on keepin on
roadrunnerian
Hi Boonyed, i had jl3 on my scooter before the franspeed race i found it was good low down but ran out of power at about 7000 revs. the franspeed revs well onto about 8500 i did have a sx200 gearbox but changed to the li150 box made a big difference as well.stainless steel pipes don't seem to go as good as a mild steel. the franspeed is a dear pipe but well worth it.hope you get sorted m8 i'm sticking with my franspeed. check out the dyno page to see what people are using.
lockman69
What about the new MB clubman?
