On another note, got the Aprilia clocks mounted with a custom white carbonfiber panel. Kinda hard to see the carbonfiber but you get the idea. Might change out the tach for something a bit more interesting, but will depend on how easy it is to pick up a tach signal due to the Aprilia ignition.
Rotax Lamby build-024 by PotvinV8, on FlickrWas also playing around with the headset and it looks like it needs to sit lower than it currently is. That will require some mods made to the bottom of the headset as the bracket that mates it to the fork won't bolt on as-is.
Rotax Lamby build-025 by PotvinV8, on FlickrUnfortunately, the brake master hits the legshield as it sits now so any lower and it's going to be an even bigger problem. I'm wondering if a radial master might solve this problem or if I'm stuck trimming the corners of the legshield? Going to have a clutch master as well so it's a bit of a problem at the moment, but nothing a cut off wheel can't solve!
Rotax Lamby build-026 by PotvinV8, on Flickr
Rotax Lamby build-028 by PotvinV8, on FlickrAnyhow, thought I'd post a bit of progress, however minor it may be. More to come...
