Lambretta handle bars
Right thinking caps on gentlemen,,RE my new project and the auto front end, IF i was to fit handle bars of the NRG how the hell would I sort the left hand side gear change?..right hand side easy, headlight/ speedo a breeze BUT...gearchange :?: anyone done this and please how ;) ...I know the D model has it (3 speed) and early lamys have it but how..Can you get rearsets with gear change on left hand side as a motorbike :?: ..May have to change the name from project recycle to project scooterotica.org :?
corrado wrote:It that what this part is for....?
http://www.lambrettaspares.com/sparepar ... 0285k.html
Now thats what makes this site the best..perfect mate if it changes gear as well which it looks like it does...trouble is...Temporarily out of stock Check back later..please Mr Hepworth could you ask MRB to get some more :mrgreen:
one alternative i have in mind is use a motor cycle throttle housing that has twin cables BUT you would need to remake the throttle sleeve in metal as you will need to mount a clutch lever to it ,but as you seem to have free run of an engineering shop :D
Bufficus
OR make a hole in the nrg bars just on the bend so it is in the centre as you look down the bars end on so that a standard lammy gear change and rod will pass through ,weld a sleeve in and some cable adjusters ,not pretty but would work
Ian Hepworth
In the queue for the machinists.
Thanks to all of you..looks like thats solved, a couple on the market both look to do the job, think I will put an ad up for a second hand one bet theres a few at the bottom of draws and boxs in sheds and garages..remember recycle. :smug:
