Scootrs Inboard Disc Brake for drum links????
shimflips
Main scooter: lambretta silver special
Thinking about getting a Scootrs inboard disc brake for drum links for my silver special. (can't afford to buy new forks/links to fit standard inboard disc).
Has anybody bought or used one, and do you rate it?
cheers
Haven't used one but have a mate that might be selling one! Fitted it then removed it, preferred the outboard look.
Bombay Mix Pilot
Hi, I got one of the drum link inboard disc brake units, it works well enough looks as good as an Innocenti original ( castings are as good as the originals ). I have had a warped disc problem but this was probably down to a badly adjusted hydraulic conversion. Make sure you buy wisely and change the pads for quality European ones. All in all a good way to get the original look with drum links, not too pricey either. Hope this helps a little.
Andy
shimflips
cheers lads, much appreciated.
I have fitted them, as said, nice castings and went in ok
    Users browsing this forum: No registered users and 85 guests
