Piston advice Plus
dapper
Been given a 200cc cast cylinder and head off a mate with brand new piston which is stamped 66.6mm and is a three ring piston, but it's too slack in bore so need a 66.8 (He never said the piston came with the cylinder, just a generous gift). Which make of piston and who from please?
Secondly, how do you tell a Stage 4 from looking at the cylinder? I've opened up the transfers nicely, but have no idea from looking at it whether it's a Stage 4. Is there something about the inlet port or the timings and if so, waht are the measurements from the top of the cylinder to the transfers/inlet/exhaust ports. Would posting a photo of the cylinder help?
I Thank you
dapper
Anyone????????????????? :shock:
bristolmod
Problem is I don't think there is any specific description of a "Stage 4"- it tends to be a phrase bandied about in pubs and at meets IMO.
One mans "Stage 4" is another mans "Stage 3" or even a "Stage 6"
Sorry- may be someone with more knowledge about later
Chris
Scootering since 1968.
Muppet
Mahl piston if y ports not too wide; or an asso but the expand a little more wen hot; pistons a piston ifin it's stage 2.7 3.9 or full stage 4 an a qwarter,
C’est la vie
dapper
Cheers Chris and Muppet. But who does a 66.8mm Asso or Mahle piston?
db67
hi, i would say scooter restorations for the mahle pistons & andy francis or af's for the asso's. hope this helps db67 ;)
a piccy is worth a thousand words :D
bristolmod
use Mahle from Scooter Restorations running 3 thou clearance on a number of rebuilds- no problems at all.
dapper
There you go Sean
paulnobodyimportant
Main scooter: varies
Have a look at this link as it was a similar question that I asked with some great feedback
http://www.forums.ilambretta.com/viewto ... 16&t=39635
