What Crank/Carb
junkyard
Main scooter: SX230 TS1
In the middle of collecting all the parts to build a nice fast road/tourer, parts ive got so far are;
Polini 207
Polini 23/64 up gear
T5 fourth
Cosa 2 clutch 23t 9 (banded)
I planning on running this set up with a Revoler exhaust(if i can find one),im not sure what carb to run with it standard 24/24 or 28/30 mil but what i am really unshaw of is what crank to buy!
Been on the SIP site and its got loads of long stroke cranks but with all different timings and i aint got a clue which one to get i dont whant to spend more than say £150 and i dont want to go reed valve?
Any input would be greatly recieved,Thanks in advance.
Anytime you have a 50-50 chance of getting something right, there`s a 90% probability you`ll get it wrong.
goldeneye
if youve got a standard crank, cut that to suit, cheapest option. carb? the old 30mm delly is your best bet, or the keihin/koso 30mm . i"d use the standard P200 gearbox with the Polini 207, use the T5 4th if you like, but i wouldnt bother with the up-gear kit. pipe? there must be something cheap going to get you......going!
ducksta
cut the standard crank then long stroke it 60mm, carb 30mm delly, pollini barral but put a mallosi piston in with packer speak to harry barlow pro porting you wont be dissapointed. i ran a revolver exhaust with this set up
goldeneye
how did you get your standard crank to be a 60 stroke like?
poss rebiult with an off set pin ?
ducksta
like sean said rebuilt crank with differant pin ddnt cost that much either.
junkyard
Thanks for all the replys,cant really be fooked to go down the cutting/re rodding/welding pin etc as ive be offered the choise of two off the shelve cranks for what anit alot of money to be honest :) The drama im having is which one out of the two to go for to suit the engine im after :?:
First up is a Pinasco,disc valve 60 stroke with 110 rod 16mm pin and the timing is 123/6 degree post TDC (AS CLEAR AS MUD)
Second is a Tameni, all the same as the Pinasco but 112/6 degree TDC.
Once again Thanks ;)
ducksta
depends on your ports which will suit best will you need a packer?
Morgan
Main scooter: T5 Vespa Mk1
ducksta wrote:cut the standard crank then long stroke it 60mm, carb 30mm delly, pollini barral but put a mallosi piston in with packer speak to harry barlow pro porting you wont be dissapointed. i ran a revolver exhaust with this set up
Was thinking of putting a P2 lump in my T5 and going for longstroke. How much did the crank cost to get done or do you have to buy the bits seperate.
Cheers for reply matey ;)
ducksta
contact harry barlow at pro porting he will give you the spec and prices
