Vespa Wiring GS150 by glmods, on Flickr
Red/Black connects to CDI & no.7 on headset switch
Yellow/White connects to blue which connects to no.1 on H/Switch
It also connects with Brown which connects on Headlight
Red/White connects to Regulator
You won't be able to use that ignition switch, directly, as an ignition cut out. Connecting the red cut out wire to position 7 will connect the CDI directly to the battery in all running positions!!GLscoot wrote:Any help will be much appreciated & I hope the above is not to complicated. The headset switch is a 8 pole GS150. The Stator, CDI & Regulator are from the Pinasco Flytech.
Thanks Gary
