Vespa Winter Project
ArmandTanzarian
That's looking really tasty.
GLscoot
Main scooter: Vespa GS150
Vespa GS / PX180 by glmods, on Flickr
GLscoot
Untitled by glmods, on Flickr
Untitled by Image
Untitled by glmods, on Flickrglmods, on Flickr
Bofs
That`s gorgeous, great colour and the black sets it off great. Keep`em coming 8-)
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
victor
Main scooter: Tv175 but currently a SS210 :)
panamesc wrote:Image
I'll never be able to understand this kind of taste (very American).
The paint is just... tacky... Then the lights on the fender which makes it look vietbodge, especially together with the american tractor/Indian seat. To top everything after having spent a fortune the original PX kickstart pedal has been kept :O
Nevertheless, your build looks the piece, really like it although I'd sanded/wirebrushed the chassis down instead. Having said that it does look very neat, almost metallic :)
GLscoot
Yesterday, took the plunge and contacted a fuel line to the carburettor and with a bit of kicking swearing and trying every position of the GS150 key, she started no problem. Very surprised, rear light on all the time. Horn doesnt work,headlight doesn't work and brake light doesn't work. i did not connect the battery, as the last time i burned out the CDI unit. Wiring is a fk nightmare, i just don't get it. Oh, the horn switch is the cut out switch. I think i might connect the clutch and gear cables and take it to someone who knows what there doing.
GLscoot
Vespa GS150/LML180 by glmods, on Flickr
Scooter more or less finished, runs through the gears ok, will need to tighten cables as I go. Still got to cut the panels, buy the drop bars and digital speedo, but I will run around on it for a month or so to make sure everything is ok. Lights and horn don't work. I did post my electrical woes but the new server has deleted the wiring diagram I used. I'm hoping it will be re-appear and someone can sort it out for me on the forum. If not I will need to visit my local scooter mechanic.
GLscoot
Still got to find a Gandolfi seat bracket, not to keen on the original as the Gandolfi Seat is smaller and more sporty looking than the one in the pictures.
GLscoot
Nightmare, my wiring description and pictures have gone. I will post the pictures and write the description again. I really hope someone can help.
GLscoot
CDI UNIT
Vespa Wiring GS150 by glmods, on Flickr
Red/Black from Stator to CDI, the Red wire piggy backs on the Red/Black and is connected to no.7 on the headset switch.
Black wire is earthed on the Flywheel Cover Screw.
