Best place for fixings
maxi
Main scooter: LIS 190
Hi all anybody recommend a gud place to get fixings for me cutdown ,there some expensive places out there LOL,or would my local fixings place would be best place? Anybody got a lammy parts list?
Cheers maxi
Ride it hard
Buy local, it'll be much cheaper. There is a fixings list floating around, I don't have it to hand but can post tomorrow if it hasn't been posted already ;)
rog60
Main scooter: Indian GP200
I've compiled a list of all standard fixings on an Li series Lambretta, which I could email to you?
It's about 6-7 pages long and was compiled with the 'assistance' of The 'Unofficial' Lambretta Manual Update book
J1MS
If theres a JR Websters near you, and you can get a copy of the Unofficial lambretta manual....Websters sell or can obtain most screws nuts and washers, I get my 7mm nuts and washers and pressure plate screws off them, as well as most of the normal metric nuts washers and bolts....
Here's the list I have for Series 3...
1.Horn Casting
M5 x 10mm Pan Head Slotted Screw (2 Required)
M6 x 18mm Allen Head Screw + 2x6mm Conical Washers (2 Sets Required)
M5 x 20mm Countersunk Oval Slotted Screw + Finishing Washer (2 Sets Required)
M5 x 16mm Hex Head Bolt + 5mm Large Diameter Conical Washer (2 Sets Required)
M4 x 10mm Countersunk Oval Head Slotted Screw (Oval is optional, just looks better) (2 Required)
2.Front Mudguard
M5 x 25mm Countersunk Flat Top Slotted Screw + 5mm Nut, 5mm Conical Washer (2 Sets Required)
M5 x 20mm Countersunk Oval Slotted Screw + Finishing Washer, 5mm Nut, 5mm Conical Washer (2 Sets Required)
3.Floor Set
M4 x 10mm Pan Head Screw + 4mm Speed Nut, and
M4 x 20mm Pan Head Screw + 4mm Nut, 4mm Large Diameter Washer
M4 x 10mm Pan Head Screw + 4mm Speed Nut (2 Sets required)
(In lieu of speed nuts, you can use plain nuts and washers)
M4 x 20mm Countersunk Oval Slotted Screw + 4mm Nuts, 4mm Washers (4 Sets Required)
M4 x 25mm Countersunk Oval Slotted Screw + 4 mm Nuts, 4mm Large Diameter Washers (2 Sets Required)
M4 x 10 Countersunk Oval Slotted Screw = Finishing Nut (2 Sets Required)
14 x 5mm Nuts
14 x 5mm Conical Washers
10 x 5mm Speed Nuts
M5 x 25 Countersunk Oval Slotted Screw + 5mm Nut, 5mm Conical Washer
4.Dual Seat
M8 x 25mm Hex Head Bolt + 8mm Nut, 8mm Washer (8 Sets Required)
4 x 8mm Flat Metal Washer
Large Diameter 8mm Plastic Washer. (4 Required)
5.Frame ‘L’ Bracket
M7 x 20mm Hex Head Bolt + 7mm Nut, 7mm Conical Washer (2 Sets Required)
6.Engine Cowlings
M5 x 10mm Slotted Hex Head Bolt + 5mm Lock Washer (7 Required)
M8 x 14mm Hex Head Bolt + 8mm Conical Washer (1 Required)
7.Headset,
M5 x 40mm Countersunk Oval Slotted Screw + 5mm Countersunk Internal Lock Washer (2 Sets Required)
M6 x 10mm Countersunk Oval Slotted Screw (2 Required)
M3 x 20mm Countersunk Oval Machine Screw (Philips Head) (4 Required)
M3 x 22mm Countersunk Flat Slotted Screw (2 Required)
maxi
Could you email me that list rog cheers mate
Maxi_125@hotmail.com
rog60 wrote:I've compiled a list of all standard fixings on an Li series Lambretta, which I could email to you?
Ride it hard
maxi
Cheers soulsurf,main things iam looking for are forks nuts,shocker,engine,wheels,headset,lever bolts ,going to change sidecasing to Allen key ones
Ride it hard
dapper
maxi wrote:Cheers soulsurf,main things iam looking for are forks nuts,shocker,engine,wheels,headset,lever bolts ,going to change sidecasing to Allen key ones
Why??? Taking bolts in and out of an alloy casing will wear the threads. You are better off using studs.
Agreed, allen bolts look nice but f*@k up the threads on your casings leading to oil leaks, don't do it.
maxi
Cheers lads I'll scrap that idea then
Ride it hard
    Users browsing this forum: Google [Bot] and 16 guests
