T5 classic clutch prob
Tosh
has 172 malosi,sito exhaust,cosa clutch, put a new cruciform checked plates they seem to b ok cables oiled and free
but its hard to find gears when your stopped and about to set off,even 1st thing at morning after letting it tick over
a bit when you come to put it into gear it jumps forward and stalls,my son is getting a little wound up,is there owt i can do
not looked at basket in case there are lips on what are stopping he plates.
Any help would be appreciated. Paul
roadrunnerian
Hi Tosh m8,
the cruciform is it a genuine one,also you may have to check your basket on your clutch they do have problems unless they are a genuine.i got a corsa clutch from beedspeed sent it back using my standard clutch with uprated springs. hope you get sorted ride safe m8
ducksta
plates stuck together or clutch basket
Tosh
thanks ian & ducksta for that, will have to try and have a look over the weekend lad needs it for 3/4 hour ride each day to work and back
soulboy
have you adjusted your cables ..try that
