Monza reed options
Boreham
Main scooter: GP225
Could anyone please advise the various setups possible when replacing the std monza reed block/inlet, the std one has the recessed block but assume you can use an aftermarket reed block if you change the inlet (LTH or similiar)
Any advice appreciated.
Darrell Taylor
Main scooter: LAMBRETTA
are you looking to replace because yours is broke? or want better panel clearance or performance improvement?
Boreham
Main scooter: GP225
Hi, it is a performance upgrade
You can change the manifold but you'll need to do some measuring of reeds because I believe the std Monza reed is narrower so using an RD etc reed may need some work.
Darrell Taylor
thats right the reed box needs porting out to accept the larger reed assembly
