carb help please.
lammer205
lads i'm looking some help with a carb setup if you can help,honda205 stage4 22mil dellorto through airbox with elbow removed and clubman exhaust, have put this up under carb setups also any help would be great ,cheers Hicksy.
J1MS
Ive only ever run the 22mm Dellorto through the air box with the elbow fitted....and the biggest main Ive fitted has been a 138 and I had to use a Mikuni jet as Dellorto didnt make one that big....but the Honda 205's Ive done to run on a standard GP air box setup usuallu end up on a 125 or 128 one needed a 130 main but I think the carb was worn all the other jets remained the same as standard GP200 but the pilot sometimes needs to be changed for a 48.....Hope this info is of some use.... :)
lammer205
Cheers jims for the info will try around those settings,do ya think the elbow removal would make much difference, to the ser-up,thanks Hicksy.
