dodgy voltage regulators
depechediki
Main scooter: gp ts1225
anyone had 12v coming out of the earth on a regulator before??
Yanker
No, maybe wired 'wrong' : 12v out of Terminal 2 as well? If so then it's shorted and 'dodgy' (unless you wired T2 to the frame and then metered the earth that is)
depechediki wrote:anyone had 12v coming out of the earth on a regulator before??
Er....one end of the lighting coils is connected to earth at the stator and also one side of the regulator output so I would be suprised if I DIDN'T :?
welcome
Hello, please re post your question in the relevant section. ;)
firekdp
If you haven't got the earth of it connected (which you can't have), then you should measure voltage from it.
