mb 190 what set up
crooky
Main scooter: 1960 series 2 li stg 4 175
got a mb 190 kit road tune with yam converted 115mm conrod wondering whats the best set up thinking a 28mm dellorto open mouthed with clubman running li125 box with 16 sprocket giving 5.3. what performance/power will i be looking at. not bothered about top speeds just a nice smoothish rideable torquey motor for rally use to cruise with a bit extra for overtaking and keeping up. Thanks for any advice
The man who doesn't read has no advantage over the man who can't read
Donnie
What did MB advise?
Donnie.
ForemanBob
Main scooter: GP RT230
I run a Harry Barlow suzuki 190, 60mm crank. Run BGM 30mm Carb via Breathing Sweet filter, ADS3 road pipe.
Really like the setup, but you need a higher gearing than you have to get the best out of the ADS3. I run 4.4
Donnie wrote:What did MB advise?
Agree, give Mark a ring :grin:
crooky
Spoke to Phil said it was a good all rounder and would work well with one of their new clubmans. said it was capable of between 15-18bhp I presume thats with a new clubman or expansion. Should be good for what I want a torquey cruiser with my carb n clubman setup. Its on series 2 so gonna leave the gearing alone I think. was hoping it was the kind of power a small block muggello puts out or is this not realistic.
thanks for the info everyone.
Elite-225
Main scooter: GP 225
I would imagine it will be more than realistic.. No bother.
crooky
The kit has a brand new wiseco forged piston will that need any work done to it as in shortening etc. thanks for any info much appreciated
crooky
As previous you'd be best directing these questions to MB, he tuned it and will be able to advise best from the info about the tune bearing in mind the assumption that nobody else has fooked with it since.
Anything anybody says on here is opinion or speculation without the barrel, piston and measurements in hand.
soosh
Surely you got some advice with this kit?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
