jetting help with carb info
gusggl
dellorto 30 mm phbh bs.atomizer av266,neddle x7,main jet 150 or 155,pilot jet 55 choke jet 70 .........I have a monza 225 with a 30mm delorto carb, and a jl.and was very surprised to find it had a big flat spot at the top half of the rev's It would start and idle with no problems but would start to splutter and fart half way up the rev's.if you go past half way it wud bog down and slow its self down. if i give it some welly from start its sound but can not go past half rev's at all its annoying. :flaming: i no its to do with jeting..... hellp....
leigh
put your complette spec on here ie carb and sure someone can will be along with help, have you looked in the carb section maybe a set up there similar.
Leigh
gusggl
leigh wrote:put your complette spec on here ie carb and sure someone can will be along with help, have you looked in the carb section maybe a set up there similar.
Leigh
thanx leigh will do that.....
