px200 polini venturi air intake,anyone fitted one
andy66
Main scooter: series 3
ive got a standard p2 with a sip road pipe,ive had my eye on a polini venturi air intake kit for a bit.
has anyone fitted one??ive searched all over for reviews but can only find ones on the lml forums.
read a few bits about people who say they are fitting one but then nothing.
itd be good to hear peoples experience of it
cheers
ducksta
i have one on my t5 suzuki 185 conversion works a treat sounds cool too
chrisM
Main scooter: Vespa GS 200
Ducksta, do you run your scooter with the engine panel fitted? If so, do you notice any difference on a long(ish) run, when your carb sucks the preheated air? And did the foamfilter ever come loose?
ducksta
run pannal on, and i cut the old rubber intake down so it still blows cool air streight at the foam filter
Train Driver
That nice Mr Diablo is the man to talk to
andy66
ducksta wrote:run pannal on, and i cut the old rubber intake down so it still blows cool air streight at the foam filter
that sounds like an idea..
how do you go on with the foam filter??do they last,do they get clogged up easily??
what carb are you running ducksta?
philhnottm
Main scooter: px (s)
Alan Terry at Diablo fitted one to m Recent Polini 220 build so guess they must be good !
ducksta
standard carb sat on top of a dr reed valve, no blow back through carb= economical, and never lost anything on the dyno
ducksta
filter seems good quality time will tell on that one
roadrunnerian
i fitted one to my t5 noticed it brought the power band a bit lower down the rev range runs with standard carb 125 main jet with panels on i like ducksta's idea of the rubber hose nice one m8 get one fitted and enjoy ride with a smile
