Varitronic, Using DC Option?
firekdp
No. Sorry Mike should have said the AC Indian switch. These were designed to seperate the 12V headlight from the rest of the circuits (as these remained 6v). Blue can be used for the DC in and will feed yellow and black in positions 2 & 3. Use brown as the AC feed into the switch and this will feed only the orange (supply to dip/main switch) in position 3.
firekdp wrote:No. Sorry Mike should have said the AC Indian switch. These were designed to seperate the 12V headlight from the rest of the circuits (as these remained 6v). Blue can be used for the DC in and will feed yellow and black in positions 2 & 3. Use brown as the AC feed into the switch and this will feed only the orange (supply to dip/main switch) in position 3.
Thanks Kev, you meant his one? http://www.scooterrestorations.com/lamb ... ac-indian/ Are these switches any good?
So, take a blue wire from battery +ve to yellow & black of the ignition switch, and connect any gauges to ignition yellow? Take the loom brown to orange of the ignition switch to power the light switch? What about the DC horn?
firekdp
soulsurfer wrote:Thanks Kev, you meant his one? http://www.scooterrestorations.com/lamb ... ac-indian/
Can't comment on the quality of them as haven't used one. If you buy one, confirm with them that it is based on the Indian 6v/12v type and not remade to Italian spec.
However, I think I've got one somewhere I bought from Allstyles (albeit with the horrible plastic covered keys) that I never used. PM your name & address and if I find it you can have it to try.
Thanks for the offer Kev, I'll check with SR first and see what they say, save you from hunting around right now ;-)
wack 63
Main scooter: '71 GP TS1
I have that type of switch and it is a copy of the Italian DC one.Good quality and the key fits well unlike the plastic coated ones.
Grumpy225
That's good to know, I was not aware of that. There arn't too many SIL bikes in the US, I'm stuck working on 1 owner barn finds that have never been opend up and have less than 1k miles on them. :anbrgin;
PM sent ;-)
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
