MEC crank question?
servetakid
I think i read some where on here only certain MEC cranks need piston shims fitting, can some one tell me which do and dont?
Cheers,
Speed Demon
If it has shims at the big end then it doesn't need any at the piston.
Get to SULK
servetakid
Ok cheers sticky, I need the piston shims.
Speed Demon
If I were you I'd spend whatever it costs and put in a better crank instead. I don't know what the budget MEC race crank costs now (about £120 last time I looked) but if you sell what you have it shouldn't be a massive extra investment to get a race crank, but the better big end bearing and no need to use piston shims will be worth the extra, even in a stock motor. I might even have a race crank to flog if you want one.
Get to SULK
Jazzy
Sticky , if you were to re rod a crank, what big end bearing would you recomend
Speed Demon
I'd let Harry Barlow (Pro Porting) do it :)
Harry uses Japanese silver-caged bearings but obviously which one depends on the pin and rod you are using.
Get to SULK
    Users browsing this forum: Semrush [Bot] and 65 guests
