Drive side bearing
Jeff T
Main scooter: GP150 & LI150 S2
I've freezes the bearing and heated the casing but still can't get the swine in, Keeps going in on the p155 anyone any other ideas.
mick1
Main scooter: Li Avanti 225
Vespa or Lambretta ??
ducksta
my guess its a lambretta with it been posted in this section
Grumpy225
There could be damage around the bearing home but with out a photo it's just a guess. Typically the case is not clean enough to allow the bearing to drop right in. Remember bearings are an interference fit which means there is no space between the two surfaces.
For the drive bearing you should get the case plenty hot, no need to freeze the bearing (it's a waste of time and and can add moisture between the bearing and case).
What I typically do is set my propane torch aimed at the case where the bearing goes and let it cook for about 7-10 min. Remove torch and carefully insert a slightly oiled bearing. Keep it nice and level it should drop right in. No pounding on it. For the drive side it helps to have a bearing holder (big handled screwdriver helps) so you can guide it in to place.
Jeff T
Yeah lambretta s2
Yes, what Grumpy says, I had exactly the same trouble last week, froze bearinbg andf heated the case. Managed to drift it in eventually after a few false starts but from what Grumpy said, I didn't give it anywhere near enough heat.
coaster wrote:... anywhere near enough heat.
hot enough to boil spit is the measure I use
Jeff T
Cleaned up and plenty heat and it dropped in, cheers for the help.
I use one of Rich Presleys bearing fitting tools, not cheap but given how versatile it is and how many times I've used it then it's been an absolute bargain.
http://www.richpresley.co.uk/lambretta- ... l-42-p.asp
You don't need as much heat plus I don't like hitting bearings with punches.
    Users browsing this forum: Semrush [Bot] and 9 guests
