special runs better with choke on.
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Cheers russ. i will look out for some champion ones ;)
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
Boothy_the_makem
carlos fandango wrote:
Boothy_the_makem wrote:Yes ngk :(
To add to the plot a mate called round today . said 5 of them went on a run last year. all filled up at that station and ALL broke down :(
What is the equivalent champion plugs for the ngk 7's and 8's ?
The heat range on champion goes the opposite way to ngk
NGK lower number is a hotter plug ..Champion lower number is a colder plug
A b8es is equivalent to a N3
if you take away the plug number away from 11 it will give you the other make equivalent
So an NGK B7 is eq. to champion N4 :D ( this method dosent work for the entire range but does for the common lammy plugs ) ;)
But i use a N3 in all my engines with no problems Std 200 to RB240 :D
Russ
Cheers russ i will get some and see how it goes.
Took the special out for a run yesterday and seemed fine on same plug/petrol.
except for one time i forgot to turn the fuel off and needed a few kicks.
dont have a problem with the vespa. wonder if the flooding of lambrettas could affect the spark plugs to break down ???? i regularly forget to turn the petrol off on my lammies :) doh
Boothy_the_makem
Well its run fine lately. filled up today . too much acualy, couldnt get enough oil in. what a dik i am :)
    Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
