porting steel barrel
Twinny
Main scooter: suzuki 185
i have been reading about the suzuki conversion on here which i will have a go at at some piont
the question is about the widths of the port in the cylinder,reading dave webster tuning manual it gives hieghts of ports but no mention of widths,how would i work them out
cheers john
Adam_Winstone
But he does give you % of bore details for exhaust port width in the porting chapters, which then needs to be applied to any piston/bore diameter that you port.
You'll find that most people today will suggest that you can go wider with decent modern rings, however, you then get into a debate about port shape and how many miles you should expect out of a kit before it drops a ring and knackers itself! Dyno figures always show a power increase from wider ports... then again, many people waiting on the hard shoulder might think differently.
Good question... no simple answer ;)
Adam
PS - I might be thinking of a different 2-stroke tuning bible (certainly does) but I think Dave does make comment in the tuning chapter.
Stokie
If you're interested I can take the measurements from the port map I made of my SR190 barrel which has been tuned by Harry Barlow to suit a Suzuki TS185 piston and TV175 length con rod.
Twinny
Stokie wrote:If you're interested I can take the measurements from the port map I made of my SR190 barrel which has been tuned by Harry Barlow to suit a Suzuki TS185 piston and TV175 length con rod.
thanks that might be handy soon but at the moment i am trying the first standard li150 in the webster manual with standard rod
cheers
johnd
Main scooter: 1970 Dl125
What tools are you using to cut through cast iron?
Twinny
johnd wrote:What tools are you using to cut through cast iron?
hello johnd i am using houshold electric drill with differant shape rotary burrs then dremell with sanding discs
Twinny
Adam_Winstone wrote:But he does give you % of bore details for exhaust port width in the porting chapters, which then needs to be applied to any piston/bore diameter that you port.
Adam
hi adam has it got something to do with position of ring pegs in the piston
cheers john
Muppet
41.6 is a loverly number
C’est la vie
Solerunner1
Main scooter: GP 190
I've always followed the rule(from bell's book) of 62-65% of the bore. He also says some take the width up to 71%, but that ring wear becomes unacceptable at that level. I always shoot for 65% for intake and exhaust and it always works. Appears to be safe, but probably not the maximum
Twinny
Muppet wrote:41.6 is a loverly number
i assume you meen 41.6mm wide but that is probably on a larger cylinder
i am using a 57mm bore and -65%=19.95 then take away the 19.95 from 57=37.05 is this right or completly wrong
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
