Is anyone running one of the Sendec rev counters?
Have fitted mine as per instructions but can`t get a reliable reading,it`s all over the place.
Is mine a dud or has anyone any tips?
Anyone running a Sendec Rev Counter?
- soulsurfer
- registered user
- Contact:
There's a delay in the reading if that's what you mean?
gaz_powell
- registered user
- Contact:
mines all over the place - it was fine on the stand when i first put it in then on first run out it went mad
i recognise that there will be a delay
sometimes it seems okay then other times it seem badly wrong
going to redo cable before kelso and see what occurs
im using one with no probs...exept for a lube/maint check which popped up but its since reset itself,have you wound the wire enough times round the ht lead and taped it?is the other end snuggley fitted into its groove on the guage...your not running a variatronic by any chance?they spark twice per revolution so will read double..
there will always be some delay with a dig rev counter,i use it for when im cruising/speed check etc...your not going to get a gear change indication from one of these
- Bofs
- registered user
- Main scooter: Zundapp Betta 500
- Contact:
Same problem as Gaz, just seems to be all over the shop.
Fitted to an old-style px conversion.I fitted it to gauge engine revs at cruising/max speed to give a more accurate gauge of engine performance than the speedo itself.
I reckon I`ll do the same and reroute cable and try again
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Bad Samaritans SC
gaz_powell
- registered user
- Contact:
did exactly what it said in the instructions - made double sure the cable was sat correct in the unit and wrapped it round the amount of times it said - but i didn`t tape it i used a tie wrap as it said - could this be problem?
i`m using indian electronic (rewired, with italian pickup!)
gonna have a look over the weekend
unless theres a batch of faulty sendec,s i cant think wot may be wrong as they are pretty simple to set up,id give the suplier a ring
