Turning mudguard cable routing
sydduckett
Are the cables on spanish turning mudguard series 2s routed any diffrentley to the fixed ones? Normally you would have a thumb size gap on the bend in the frame just behind the mudguard but on the spanish series 2 the mud guard could foul the cables as it turns... :? I think I will either have to put a cable tie just out of sight or route the cables down the sides.
Any ideas or better pics appreciated.
Ta
Sef
Angry Bloke
Hi Sef -Mine are routed in the normal fashion with the clutch/gear across the frame and the brake cable thru a hole in the mudguard . I fitted a grommet to avoid the cable rubbing through but I'm not sure if it was standard
You may need to persuade the mudguard a bit to give you clearance for cables on the frame but that's still the best route ;)
sydduckett
cheers lads, job done.
sef
