Carb set up
simonwwfc
I've got a 125 with 175 barrel and head it's been ported now I'm running a 28mm dellorto with remote filter and sterling exhaust any ideas on carb set up etc as rode the weekend and tried to open up throttle through gears and it doesn't bog down etc it just won't pull etc ?
What is it now?
simonwwfc
It's a Lammy gp ?
The carb jets / needle...give us a clue
simonwwfc wrote:It's a Lammy gp ?
lol..bit more info needed Simon, whats the carb settings..main jet/idle/needle/clip positon slide..exhaust, gearing so on and so on, its important you reveal the full set up, also check the set up pages on here and try to closely match an already well set up machine with the same spec then thats your starting point...check plug colours at frquent intervals (you need a chocolate colour plug at all rev range ) not white or light (failure colour )
simonwwfc
Sterling exhaust , 28mm dellorto , remote filter , 120 main jet , clip position 2nd from top
Also think about gearing and exhaust.
simonwwfc
Standard gearing . Sterling exhaust
What are the -
Slide
Needle
Choke jet
Pilot jet
Atomiser
    Users browsing this forum: Semrush [Bot] and 13 guests
