Which of these two kits is the best basis for a HB style tune
The SIP Serie Pro
http://www.sip-scootershop.com/en/produ ... +_41470700
or the BGM
https://www.scooter-center.com/scoweb/p ... egory2=CAT
Cylinder Kit - BGM or SIP GS
- ArmandTanzarian
Spanish Fly
- Main scooter: P200e
For that amount of money you could have a cast iron Polini. Admittedly you would need a head to suit.
http://www.sip-scootershop.com/en/produ ... +_14000820
If you prefer a the standard configuration why not go for a used barrel, a rebore, and a better piston such as a Grand Sport?:
http://www.sip-scootershop.com/en/produ ... +_12090000
or what ever the piston is that HB supplies?
SF
SF
gaz_powell
if i was doing it again i would get a barrel and bore it to take a SIP GS piston 66.5/ 66.7/ 66.9 mm depending on the size of the barrel you get or a HB 68mm piston - both pistons use thinner 1.5mm rings (BGM uses the standard 2mm)
when i had mine done Harry used the brand new genuine piston i had at 66.5mm he had no issues with that but did try to get me to use one of his - but i didnt want to bore a brand new Autisa barrel from 66.5 to 68mm
I`m just about to start on a barrel (from the back of the garage) bored to 67.5mm to match a cheap thin ring piston i picked up - first impressions it appears to be decent quality - same weight a standard piaggio and good quality thin rings (might be a beedspeed one ?) - just blending and matching the ports, enlarge exhaust, increase windows in piston
- ArmandTanzarian
I would use my own barrel and head but for reasons I can't be bothered to explain, they're no good (well - maybe the barrel is). Might go the second hand route if I can get a barrel and head for reasonable money.
johnny rotten
- Main scooter: px200e
Thought I would have to find a barrel piston and head for modification when I bought my HB 207 top end but harry supplied them as I didn't want to p/ex my standard 200 top end
Harry's piston 68.0 and 68.5 uses wire rings ( Rik) from an old spec of cr250 honda, they are 1.2mm thick and the pistons were made to suit these rings, all the rest use cast rings.... which will not stand a wide exhaust, max around 44mm, approx 64%, wire rings allow wider approx 46mm, 67% for road longetivity.With cast rings the shape of the port has to be more oval and well chamfered, with wire rings the corner radiuss can be smaller approx 8 to 10mm. On a P2 cylinder you want width not height, Polini got it right!
