bearings codes
following RinB's post on viton seals,
i need to get some bearings this week and wanted to go to local bearing supplier rather than have to order through a dealer and wait for the postie.
So what are the codes and sizes of the engine bearings ?
  • drive side
    mag side [GP200]
    gear cluster needle
    layshaft needle
    end plate
got the rear on order, and the clutch bush.
have I missed any ?
dapper
I get mine from either RS Components or Apollo Bearings. These are the sizes to quote
DRIVE SIDE 6305-2RS1 RS 285-1074
MAG HOUSING FAG £32.10 NU2205 GP APOLLO
MAG HOUSING NU205 LI/SX RS 285-1822
GEAR CLUSTER CASING 16-22-12 APOLLO
END PLATE 6004-2RSH RS 442-0010
END PLATE NEEDLE LAYSHAFT 20-24-10 APOLLO
REAR SPROCKET (or bronze bush) 24-28-10 x 2off APOLLO
FRONT WHEEL HUB 6201-2RSH RS 442-0183
Al the RS ones comes with double rubber seals. You have to remove the gearbox side one on the drive side bearing.
thanks dapper. very useful
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
