t5 malossi 172 advice
wack 63
Main scooter: '71 GP TS1
Whilst apart you can port the inlet and carb casings,even the carb to get rid of the steps. The cylinder usually matches the casings quite well so won't need doing. You can also cut the crank and port the casing inlet to give a longer inlet period,somewhere between 180 to 190 degrees open ( ie 120 degs before TDC,60 degs after TDC).Be careful not to widen the rotary port too much or it will not seal.
C*NTSPEED
scooter republic sell stainless sterling t5 pipes or you can buy a px 125 or 200 revolver pipe and get a scoot rs t5 downpipe that fits.
dont bother reedvalving the engine or putting a bigger carb on the 24mm carb is ample leave the timing as standerd send the head off to harry barlow or diablo keep timing standerd and enjoy!!!!!
GEMINI S.C.
BLACK WIDDA'S S.C.
soulboy
joe is that right keep to stock timing settings
C*NTSPEED
yes mate ive never had to run it at anything other than standerd.... if its good for huge jet harry to run at stock then its good enough for me pal :fb:
GEMINI S.C.
BLACK WIDDA'S S.C.
soulboy
nice one joe
002pg
Thanks for all the advice, not sure what i will do, was thinking keep the standard carb on, change the exhaust and see how it goes.
Anyone got any advice on the clutch?
soulboy
if your keepin it stock then leave the clutch alone no need what so ever to change mate :bouncyeng:
002pg
cheers for all the help, going to order the kit now but was just browsing the net and wondered if these http://www.sip-scootershop.com/en/produ ... +_18030000 are the same as the kits from ve / beedspeed?
sip says race use only on there website.
roadrunnerian
hi m8 yes the sip is the same as beedspeed remember you have to have your head modified to fit or buy one off sip already modified so you can reuse your standard kit again. the revolver pipe are on e bay resurrection scooters there is a 2nd hand taff lh pipe on e bay at the moment top pipe well worth bidding on m8
002pg
cheers ian
i have bid on the taffspeed pipe
