piston to bore clearance
handofdave
Main scooter: li ts1
would an excessive piston bore clearance of 0.3mm cause my bike not to start from cold?
bristolmod
I would think so as its twice the max allowable clearance. I assume the ring gap is also excessive as well? Is there rather a lot of piston slap when you get it to run?
Whenever I get a cylinder rebored, I go for 3 thou (in old money)
Chris
Scootering since 1968.
handofdave
new rings but gap is excessive,would the wear stop the engine from sucking the fuel in,when i finally get it running and warmed up it starts first kick when hot,by the way it is a short rod suzuki
ArmandTanzarian
handofdave wrote:would an excessive piston bore clearance of 0.3mm cause my bike not to start from cold?
You probably know this but I'll mention it anyway because I didn't. If you check the clearance with a feeler gauge, remember to halve the value because the other side of the piston will be touching the cylinder.
Muppet
so im lookin at 12 thou feeler for 6 thou cleerence?
C’est la vie
handofdave
no i didnt know that,thanks for the info,so the clearance is 0.15 would that stop it from starting?
The cold weather certainly wont help.Once the fuel hits the cold engine parts it's likely to condense and introduce water moisture into the cylinder which won't help starting.
camel
Why would you half the value?the clearance is the difference between piston and barrel.not half the difference
camel
Muppet wrote:so im lookin at 12 thou feeler for 6 thou cleerence?
No a 12 thou feeler gives you 12thou clearance
Muppet
are u sure :? what if I hold the pot upside down and measure it left handed :ugeek:
C’est la vie
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
