Imola which gearbox?
10 inch Terror
Xbox live gamer tag: No.
Hi all, i'm currently running my Imola with a LI150 box and 15/47 sprockets giving a final drive of 5.3. I'm using a 30mm Delly and JL / Franspeed race pipe and AF light flywheel. If i give it plenty of welly it goes really well in 1, 2 and 3 but dies in 4th. My question is, would a pacemaker box and changing the rear sproket to a 46 and a final drive of 5.65 make it any better? Any advice / tips would be very helpful. Thanks in advance Pete.
My Imola went great with Pacemaker and 16 x 47 = 5.41 along with Mikuni TMX27 and scootrs exhaust. On a dyno it revved on [in 3rd] to well over 9k and felt like it genuinely got close to 80 [based on the traffic I'd pass on the motorway].
In quest for better cruising I changed to a JL3 and 17 x 46 = 4.98 and killed it. I would have expected it to pull 5.3 though.
john
Just change rear sprocket to a 46
psychedelicropcircle
^wot John says mines is a hooligan on the same setup :baddevil:
joespeed
which li150 box have you got italian or spanish
10 inch Terror
psychedelicropcircle wrote:^wot John says mines is a hooligan on the same setup :baddevil:
john wrote:Just change rear sprocket to a 46
That gives a final drive of 5.2 if i'm correct. What carb and pipe combo are you guys using? Thanks for your comments so far Pete.
10 inch Terror
joespeed wrote:which li150 box have you got italian or spanish
Italian mate.
Donnie
Italian mate.
Wouldn't matter if it was a spanish box as long as it's not a li150 S3 one, the S2 one is the same as the Italian :-)
Donnie.
If it can't pull 4th with 15 x 47 [5.3] , how will a fitting 46 [5.2] improve that?
joespeed
Italian mate.
are you sure?you may want to check this before you reply!
