Hi, I've got the exact same horncast embellisher but cannot see an easy way to fix it ... did you still fit the original horncast grill and was there a bracket of some sorts?
Any pics would be a great help
cheers
'Lola' winter build
Jaspvilla
- Main scooter: Lambretta Series 2 Li150
The engine strip was ok, think the fact that all that 'shite' inside had coated everything it was well preserved, although the crank was seized tight ( since freed it a bit) but put a new one in, most of the inner was saved including 3 of the clutch plates, springs, tree etc. i have the original barrell piston mag housing and head, all ok but ive fitted a mugello kit with reed value manifold, big bore exhaust original shape, electronic kit sounds and runs great!
Jaspvilla
Thanks for the speedo comment jazzyb, the picture doesnt do it full justice, the face has a light blue background and gives a great blue glow in the dark, the guy who did it for me from my design did a fantastic job
