Gearing question
OAP
psychedelicropcircle wrote:Aye jeff its for the avanti and one day itll have a mb clubby or RM clubby whichevers available first the barrel/ pistons away getting a reed valve matched etc to stop the spitback. the push doon fellas looking likely.
ron ill be in touch for a avanti gasket set.
I did a piston like this on for a guy in Southampton.
The cut out has to be central on the kit pistons as the inlet side of the piston is NOT thicker like a TS1
If you are going to get a new type invisible "Clubman" :roll: use a 4.8:1 gear ratio
The picture is not a Kit piston
RM
    Users browsing this forum: Google [Bot] and 7 guests
